Hi there. I have sony google tv xr55x90ku without built in mic. Would I be able to use google assistant hands free if I add bravia cam to my tv?
Hi @Dary_kk
I cannot see "voice commands" or "google assistant" in the blurb. My guess is you can only use the Mic on your remote.
Yes, it won't support hands free search as well even with Bravia cam. You can use the remote mic at this point.
Even though the camera got a built in mic, you can only use it for video chatting not hands free searching.
