I have a Sony tv KD55X8500E. After updating to last version, I have to set time and date manually every time I turn on the tv to connect to internet or else there will be no internet. How can I solve this problem. Thanks in advance
Hi paeyman,
Please change the time setting to "Network time" - this should solve the issue.
Hi peter
I did but had same problem after unplug and turn on again
Hi Peyman
Does that only happen when you unplug the TV?
Do you find it disconnected from the internet when you switch it on? Does it require manually connecting to Wi-Fi again?
Have you tried setting to Broadcast time?
I think a factory reset is worth trying if you're not satisfied with the current state of things.
Don't forget to mark as a solution if the issue is resolved
I posted this in another thread yesterday, hope this workaround can work here also.
Connecting a DVB-T antenna (Digitenne in the Netherlands) and then set up the TV's digital channels using the Terrestial setting. In the Netherlands, the public channels are free to air, so the TV can use these channels to sync its clock with.
It took a few hours trying all these other fixes, i did not want to factory reset. Then i realised i had this old antenna stil laying around. Now all apps work again, YouTube, Prime and also the build in chromecast.
