I've had this TV for around 2 weeks now and have had to 'restart' it 4 times as it loses connection to the WiFi. It only takes a minute or so but is this a common thing with Bravia TV's?
Nioe not a common issue, i would start by checking what speed internet you have and then work out how many items are connected to work out if thats an issue, akso try repositioning the router closer. Personally mine never dropped, but i always just use ethernet now anyway, much more stable so mu suggestion would be to use ethernet.
sorry bout the typos there 😂
Thank you for your reply, ill see what happens over the next couple of weeks.
In reply, my router is about 5m away from the TV and we have fibre. There are only about 4 or 5 devices connected when in use
Hi @Vulcanxh558
As the router is only 5M away, is it possible to use a Cat5e Ethernet cable? What is the full model number, Bravia 50X is too generic. It covers the decades of 50 inch LED TVs supplied by Sony.
