Talk Back keeps turning its self on, at least once a week. I suddenly get a very loud voice stating actions. This is very annoying. I can turn it off each time but how can I stop it turning its self on.
Hi there,
Have you tried to reset your TV? You can see more details on how to perform this here.
Let me know how you get on.
Best wishes,
Sean
@wheelwobble Are you sure you don't press by chance the mute button too long?
https://services.sony.co.uk/support/en/welcome-to-android-oreo?t=Topic4
Thanks very much for that information. I have tried pressing the mute button and it does switch on talkback after 3 seconds and gives an on screen message. I am sure this is not how it happens automatically but the good news is we can now turn it off very quickly by holding the mute button down and not have to go through settings, which my couldn't do.
Many thanks.
I have not needed to reset factory settings as a later reply suggested that holding down the mute button turns off Talkback which works.
