Hi does anyone know whether this model from 2018 uses active or passive 3D? It’s not mentioned anywhere in the manual. Thank
Opgelost! Ga naar oplossing.
Like this you mean?
https://www.sky.com/help/diagnostics/watch-sky-three-d/getting-started-three-d
I hate to disappoint you, but it will start off like that on any TV, as per step 1, below.
But skipping step 2, unless you already have some 3D glasses, move to step 3.
Does your remote have such a button?
If it does, does it do anything?
To access 3D mode on the TV:
What makes you think it is any sort of 3D at all?
Just because when I watch a sky 3D channel a left and right picture appears on the TV.
Like this you mean?
It looks like a No then! Thanks very much, appreciate it
