Hi my new Bravia 3 keeps freezing using ITV X, it's not network speed If I use my Fire stick ITV X is fine, Amazon Prime, Netflix, Disney etc are fine, I have tried going into developer mode and restricting the amount of open programs it makes no difference, clearing the caches also makes no difference.
All the software is upto date.
Hello there
I had similar problems with my tv and ITVX, thankfully i resolved it.
Please check you only have one itvx installed!, i say this because my software upgrade on my telly had ITVX bundled in the update and i didnt see it at first, so i installed ITVX as usual from the store. when i went to my apps and opened ITVX it either froze or just wouldnt do anything. finally after 2 hours of fiddling around i noticed the bundled version was the one i was opening, i only noticed because the version was a lower number than the one i had installed. So i went to settings / apps, found the bundled one, it wouldnt allow me to uninstall it but it did let me disable it, once i did that i went and opened the version i had installed and it worked perfect. Its worth checking just in case.
