When is the new android TV update going to happen as I've read that the Americans are getting there similar TV's update now
I have a XE9005
Sony apparently just released the list of models that are going to get the new Google TV interface ( I have it on my Chromecast with Google TV)
Does anyone know if the XE9005 will get that's update
Thanks
What TV model and software version are you referring to here?
You can find the model number of the TV on a small sticker on the back or on the box if you still have it.
Kd 55xe9005
Kd 55ex9005 currently on android 9 to android 10
What's the current software for your TV model? You can find it by pressing help and selecting system information.
Regards,
Gladio
