Is it possible to connect via bluetooth my ps4 pro joystick with my sony kd49xg90, so I could operate my tv through the joystick e.g when typing through tv keyboard I could move easily with jouystick instead of my tv remote?
IMPORTANT: Due to the PlayStation Now service ending, all DUALSHOCK®4 controllers (including CUH-ZCT1xxx) are no longer supported.
https://www.sony.co.uk/electronics/support/articles/00125839
Anyway, try to Pair...
@Marino.Manolo wrote:IMPORTANT: Due to the PlayStation Now service ending, all DUALSHOCK®4 controllers (including CUH-ZCT1xxx) are no longer supported.
yeah....... one of those brilliant decisions that SONY is known for. Like the PSNow, which was not available in many markets at all, is the only reason why would people want to use gamepads. I mean, let's put android on it, let's promote games in channels but then drop support for gamepad. And most likely because it just does not work with BT remotes. Every single one I tried is causing problems if remote is set to BT. But hey, it is fairly new tech, not even 30 years old so......
