My new bluetooth headphones are on CSR 4.0 which wont pair with my KD-43XE8396
is there a way round this like a bluetooth dongle to make this work?
A2DP is only supported as off XE85. Your TV does not support audio over Bluetooth which is a software limitation. Sony realized that there is quite a demand for Bluetooth headsets and restricted its usage to more expensive models. I don't agree with that. Bluetooth audio has been in the cheapest and smallest multimedia devices for years already. Sony wants some extra money for that.
thanks for your reply
Sony wont be getting another couple of hundred for more new headphones
cheers
Josalka
Your only chance is to connect a Bluetooth audio transmitter via the analog line out of your TV.
Hi
ok thanks I'll look into that
cheers
