Dear Community,
Since a few weeks I noticed that Bluetooth is disabling itself at seemingly random times. It also cannot be turned back on without a reboot of the TV.
I think the issue started after the last firmware upgrade as it was not happening before.
Current FW: PKG6.6575.0259EUA
Does anyone face a similar issue? Any suggestions to solve it?
Thanks & Regards,
Petros
I installed the v6.7140 update some days ago and it seems that the issue has been resolved as it doesn't appear anymore. Hopefully it stays so... Thanks for the tip @Joe_Dohn 😊
