Elderly parents have bought a Bravia 43XG8096 which is Bluetooth enabled, as my mother prefers to have the sound high and father does not, bought her a pair of Sony WH-CH510 bluetooth headphones but there is no way that they will pair as the TV is one of the models that does not accept Bluetooth headphones, great as it is a 2020 model.
I need to find a way of satisfying both, would a Bluetooth adaptor plugged into the TV work and if so do I go for a USB version or one using the audio outputs, although not sure if that will cut out the internal TV speakers. Any advice gratefully received.
For this model, without A2DP Bluetooth Profile for Audio connection, you can download, by a PC Browser's the Bluetooth Pair App. After that you have to transfer the Bluetooth Pair APK (APK is the installation package downloaded) into TV via USB Memory. So, install the APK by a File Manager and try the Pairing...
