x
Bluetooth connection to Xg80 for soundbar ht-s350
profile.country.GB.title
lissa19
New
Hi. I have just purchased an android tv xg80. I am trying to connect a Sony soundbar ht-s350 to it. I put the soundbar in pairing mode (blue flashing light on the front confirms) I then go into Bluetooth setting on the tv and select add a device (Bluetooth setting is on). The searching screen comes on but the device is never found. We have repeated this a number of times and each time the search screen comes up but it doesn’t locate the soundbar.
I have paired my phone to the soundbar so I’m guessing it’s the tv which is the issue. I have also linked them both through a hdmi and it does work this way (now removed to continue trying Bluetooth)Has anyone experienced this or can anyone assist?
thanks
2 REPLIES 2
profile.country.IT.title
rooobb
Expert
It isn't an issue. Your tv doesn't support bluetooth audio device connection. And btw I would never connect a soundbar using other than cables ... and good ones too.
lissa19
New
Thanks - I was beginning to think as much. Cable it is then!
Sent from my iPhone
