I have a
KD-55XG9505 and don't seem to be able to connect a bluetooth amp via bluetooth setup, it doesn't see it. Any idea ?
these are the Bluetooth profiles your TV supports:-
BLUETOOTH PROFILE SUPPORT
Version 4.2;
HID (mouse/keyboard connectivity)/
HOGP (Low Energy device connectivity)/
SPP (Serial Port Profile)/
A2DP (stereo audio)/
AVRCP (AV remote control)
What profile(s) are supported by your (make and model unspecified) anonymous Bluetooth amp?
Hi TonyEvernden , press the home button, then select Settings - Remotes & Accessories - Bluetooth settings - Add device - Select Connect. Also, make sure that the bluetooth device is in a pairing mode.
