Hi guys, i've recently got a new TV from SONY as my last SONY TV had to go back due to dead pixels. This new TV is a 49XF7003. Since owning SONY TV's i've had problems when watching SKY. When there is a fast moving clip it goes all blocky and glitchy 😕 this is really starting to annoy me now! Whether it's someone waving, adverts or someone sitting down into a chair, it goes all glitchy. Watched this program the other day where a plane came into land and the front wheel/arm was glitching right out to the point where you could hardly even see it. I've tried different HDMI slots and different HDMI cables but it still does it!! Any help would be really appreciated.
Hello @nscreech,
did you watch VoD content from Sky?
If so it could be, that the dynamic quality was rather low during these scenes which caused artifacts to appear in areas, where much of the screen content changed quickly.
In that case it wouldn't be a TV problem.
It still could be one of the "post processing" effects of the TV, yet it is hard to tell without knowing which effect is currently set to which setting.
- Nic
