Hi just bought the above tv and what are the best picture settings to use,thanks
@pauldormer wrote:Hi just bought the above tv and what are the best picture settings to use,thanks
Hi @pauldormer The best picture settings are what looks good to you. Everybody is different, so I simply use the default standard. It doesn’t matter what settings you use, your eyes soon get used to whatever you decide and it soon becomes the norm.
