Can anyone tell me the best iptv app for Sony tv, all my mates use smart iptv (ssiptv) will this work on Sony? if this can be used all I have to do is send the app mac address to a provider and that's it restart the app and away it goes.
Hi twh1948,
Could you let us know of the model number of your TV?
Cheers,
The_Black_Rose
Sony Baravia kd43x8005bu
@The_Black_Rose wrote:Hi twh1948,
Cheers,
The_Black_Rose
KD43XE8005BU
It's Android TV , so yes it will work.
I have it installed on on my XD8599 model.
@hija31 wrote:It's Android TV , so yes it will work.
Great thanks for the answer.
I’m trying to find the smart iptv app in the google play store but can’t find it. Can anybody help.
Goole have taken it out. Download it from the offiicial website.
Also instructions here,
https://www.teamandroid.com/2018/08/01/install-apk-files-sideload-apps-android-tv/
Then put it onto a usb memory stick and install it onto your tv. It's .apk file.
@Gall77 wrote:I’m trying to find the smart iptv app in the google play store but can’t find it. Can anybody help.
