I’ve been having issues with IPlayer not working properly for months.
I just assumed it was BBC, as everything else I Stream/watch online is fine
Hi. I found some other threads and they found a solution. They unplugged their tv for 10 minutes after switching the tv off with the remote.
when plugged back in again the apps work. Weird !
Do you have the latest software version installed on your TV? When you say cache, are you referring to a specific app or the entire TV (Settings - Storage & Reset - Internal Shared Storage - Cached data)?
