I updated to Oreo today with no issues on my 49XE9005
HDR is set to auto & detects in-built Netflix content without issue.
Amazon Prime HDR content not being detected & TV not changing to HDR setting.
Any advice?
Thanks
Hi Kicking_up_Dust,
It's always recommended that you try to reset your TV after any update, just to make sure it's not a glitch.. Here's how to reset your TV: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49xe9005/artic...
Regards,
Vanilla_
Hi Kicking_up_Dust,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hi Kicking_up_Dust,
Regards,
Vanilla_
Thanks that worked.
Forum not allowing me to mark as solution, as I get an error message.
Thanks again
