HI!, communication error message on TV and now Sony ht ct 390 will not work on Bravia sync. HDMI in arc as should be ,tried different cable , reset sounbar and set up correctly. Done soft reset on tv but not sorted. Sound bar works through optical cable. Tried everything on tv settings . Any help appreciated
Hi there,
We've passed your message over to our Customer Support team, and they should be back in touch with you soon.
Thanks,
Owen
Hi there,
Thanks,
Owen
