x
profile.country.GB.title
Tracey335
Explorer
Apps
Hi when I go on to my apps on sony tv, it usually says 'see all' at the end, but it's coming up 'reorder' how do I get it to come back to 'see all'. Thanks
5 REPLIES 5
royabrown2
Hero
@Tracey335
Take the apps display out of ‘Edit’ mode.
Tracey335
Explorer
Hi thanks for the reply it's actually on the home screen page where it says "your apps" I rang sony yesterday he said it was a firmware update that's why it's like that, but it's annoying cis I like to go onto "see All" 😂
LightFoot
Specialist
Hi @Tracey335  That sounds like a "brush off" to me. What is the full model number of your TV?
Tracey335
Explorer
Hi its XR-65A84L we tried putting it back to factory settings but still not worked, we have 2 tvs it's done it on both
Anonymous
Not applicable
Hey @Tracey335
I do believe this is due to the update, as long as it's done it on both of your TV, mostly it's an update by Google.
Did this update change your ability to reach all apps though?
I believe there is a tab there where you can access all apps.
