How to update just one app on TV? the only option is to get all apps autoupdate on or off but I want to chose the update for HBO but not for YouTube because the last Youtube app kills the app.
Turn auto update off, and download the updates you want manually. I guess you have to be more proactive in determining when updates are available that way, though.
I'll be more pro active but the question is : how do I update one app manually? Manual update works only for all updates available.
Hi @Yankoo
I can’t look at my Android TV right now, as it is a non-essential journey away; but if I recall correctly, you go into the Play Store and download the app you want updated, just as if this was a first install.
But hopefully, someone with the TV in front of them can chip in here.
