Hi will be grateful if anyone can help. We have a Sony Bravia and every time an advert changes, programme starts or ends we keep getting a black band appearing at the top of the screen with the name of the HDMI port and numbers relating to it, also once a programme has started we get the title of the programme and time coming up on the screen about 2 -3 minutes into the programme.
Hi @Dicko59
It sounds like you're referring to the info banner.
Which TV do you have?
On Android sets you can disable it from:
Home - Settings - Channel setup - Info banner - Disable
Hope this helps
Hi @Dicko59
Hope this helps
Many thanks for this, the tv I have is a Sony Bravia KD -49XG8196
Sorry not tried yet late home last night will hopefully try tonight will post and let you know
Good Morning Jumpy, Process worked well no more bar on top many thanks for your help once again
