Hi all,
I have an Android based Sony TV without a light sensor.
Using my smart house server, based on an external light sensor I'm setting the picture brightness and contrast via the REST API (API doc).
It all works as expected, except of 2 issues:
Does anyone knows a better way to getting the expected result?
Thank you for any advice you might have.
Cheers.
Hi @LightFoot
Sorry for not writing the model number, I didn't think it was important, because I thought the API is shared between the different TVs.
Anyway, the model of the TV is KD-55X85J
Cheers.
