Hi
Ive had an A9 OLED for less than a week. Updated it yesterday
most native apps (prime, now TV, iplayer, Disney) are now playing in approx 1.5 speed with no sound at all
Any help please? Just listening through TV, no soundbar or anything
many thanks
Really sorry not able to help. We have had this same problem since we subscribed to amazon prime and have been unable to solve it. Sony are about as helpful as a chocolate t-pot!
Having same problem some tv apps have no sound ??
been into menu’s with no joy
Resetting the TV worked for me. The problem resurfaces from time to time.
Also got the A9. Same problem occurred on mine since new software update. No sound on iPlayer and no ‘beep’ sound when changing channels etc. Switched TV off and unplugged it from mains for about ten minutes and sound has come back. Hope this has fixed it.
If you have the latest software version, try clearing the TV's cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data).
Thank you for your reply.
Searched the menu’s and cannot find device preferences, any idea where we can find it?
thank you
The settings are model-specific, could you let us know what model you have so we can help? ^^
PS: They can also differ depending on the software version, so let us know that as well.
- JD
Dont know what is causing it but occured three Times today on brand new A8!
Restarting tv solves it but this is a bad thing!
This was not a solution in my case. Restarting the tv was though.
