Hi;
I would like to know does logitech harmony hub will supports to sony android tv KDL-50W800C. I know that harmony hub will support amazon echo dot alexa. but ,i am confused will that work in combined with sony KDL-50W800C?
Thanks in advance for your support 😊.
@zakirox wrote:Hi;
Hi @zakirox
Your TV model is compatible with the Harmony Hub. https://support.myharmony.com/en-us/compatibility
The Harmony Hub does not connect to your TV, all it does is act as a infrared remote control. You connect the Harmony Hub to Alexa using the two Harmony Skills. The Alexa main Harmony Skill uses the Harmony Activities and Favourites, an example Alexa, turn on TV or Alexa, turn on BBC1. The Harmony - Secondary Hub Skill uses some common commands like Alexa, ask Harmony to increase volume.
I have been using a Harmony Hub and Alexa with my Sony TV for ages and can confirm it works really well. Do not use the Alexa app on the TV.
@zakirox wrote:Hi;
Hi @zakirox
