I won't labour the point made in another thread but some may recall for the past 5 days my machine has failed to start after a factory reset and re-setup.
I have posted the solution here for those interested.
http://forum.xda-developers.com/showpost.php?p=62768643&postcount=130
Note adb and fastboot needs to be installed on your laptop; Do a Google search for adb install
Not one part of the solution was proposed by any member of Sony's Support Team. They are not technical and know not of what they speak.
Couldn't agree more with what you said. Sony technician that came to my house did nothing more than just looking at my problem, and shaking his head. I am still waiting for Sony to come back to me.
Any chance to fix the problem by not performing those steps you described because I didn't enable developer option in the frist place ? If I can have access to Android Settings to do a Factory Reset, I think the problem can be resolved. Really frustrating being stucked in initialization mode and not able to go any way.
Thanks
Pang
