Just had a software update a couple of days ago.
Since the update my TV controller is not working properly {new batteries}... the sound button just runs up the scale on one press and nothing and everything is working slowly.
Final straw.... each button press now receives a voice response. This happened or came on by just picking up the controller without touching any buttons.
Looked everywhere to find how to switch this off.... cannot find anything.... help would be appreciated.
Is the Update flawed or just my set?
I would suggest to do a factory reset after the update to re-initialize the TV.
This should solve the issues you're facing.
