Having just purchased a 75XD9405 and having a few problems to understand the setup of the HDMI connections can someone explain why my Sky Q box in HDMI 1 is labelled as Player 3 and my Panasonic UB-900 in HDMI 2 is shown with no player number. And even though I have set up HDMI 1 & 2 as enhanced and labelled them when I go to the Settings Menu only my connection for the Sky Q box is indicated?
Also what happened to player 1 & 2 and what does this Player number mean or achieve, and how do I set reset this?
Not the easiest TV I have ever set up.....quite confusing
Thanks for your help
Hi there,
I'm looking into this and will get back to you with an answer.
Cheers,
Sean Mc
Hi there,
We have an update for you.
It is possible to manually rename the inputs by going to Settings > External Inputs > Manage inputs.
Let us know if you need any more help.
Best wishes,
Ed
