thinking of buying the KD55AF8BU OLED TV but does it support DLNA
Cheers Mark
On an Android TV is quite a strange question.... since it allows for you to add any player available you want. In any case the stock Video player does support DLNA (as well as most of other alternative players such as Archos, VLC, etc.)
thanks Never used Android but I have a NAS drive with all me music on and i currently use DLNA to my sony TV/Bluray to play them through the AV amp
You can of course do whatever you did with the Sony BDP via DLNA also with the Android TV (using the stock Music app in this case). Via a different player you could avoid also using a DLNA server accessing directly the SAMBA share on your NAS. Just in case.
