Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
@frogger38- correct Any info received, I will post back to the forums
You're welcome
Sorry guys - I have had to remove a post of mine - information is not quite correct.
Hi Quinnicus, does this mean the OTA update is still being rolled out?
Take that as a yes.
Thank you, that's great news. I think I'll be taking the plunge this weekend!
Found one very annoying feature/bug from epg.
I use favourites in EPG to filter unwanted channels away and TV button from remote is configured to show digital "source". Every time when i press TV button ftom remote tv changes epg source from favourites to digital where are all channels listed.
Is there any way prevent this?
Any chnce of some stats on how many downloads hve been done in the UK. Ideally stats on number of tickets
raised would be good.
It's hard to guage how trouble free this release is as mostly people only post if there are issues. Looking at a lot of the posts they seem to be from tech savvy guys who are pushing the TV rather thn timid guys like me who want TV, Netflix and using it as a monitor.
I'm still not clear if I'll still be able to record if I use the USB drive as system extension.
Well done to the pioneers out there who are getting the pain.
you won't. You can't use the same drive as internal storage and for recording.
Can you choose how to use the attached drive?
Hi there
Unfortunately the answer is no - Sony wont release those stats.
yes. For each drive you plug in you get a full screen popup where you chose what do you want to do with the disk.
But ATM, handling the disks is quite broken. See my two topics about issues I encountered so far.
Didn't try the recording yet (apart from trying to use the same drive as internal storage).
