Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
Updated mine around lunchtime. 1st time with no issues. Seems less laggy . TV been on all afternoon.
KDL-43W805 2015
I don't know what just happened, or if it has something to do with the update (though I doubt it). My TV won't recognize the update, as a result, I'm stuck with the 'old' Marshmellow update for now. But all of a sudden, after hours of trying, restarting my TV and what not, the EPG suddenly refuses to show every other channel information, and it won't let me move the selector down. Has anyone else experienced this? Maybe in the process of trying to update to the new Marshmellow?
Hi guys,
Did update in february... Updated 2 hr ago. Went fine and smooth.
So far so good but have not much troubles before exepted some reboots so only time can tell if it's better
Is this update via USB only? Nothing is showing on the tv itself.
Updated to the latest firmware last night and everything seems good so far. Menu has been tweaked and looks better as well as smoother. Updated all the apps as well. The only annoying thing I noticed was before I updated Google cast I tested a film out from my mobile and audio and video played fine. However after I updated the app, video was smoother, however there was no audio. So it seems this is due to the app not the firmware update.
So all in all the update seems to have ironed out a few things, however I'm sure there will be further tweaks and improvements to come.
hi i also would like to know if you find out
regards
hi i would also like to kow if you find out please
