Hi All,
Just purchased a 55 SD8505 from John Lewis, it was previously a display tv but John Lewis offered at a great price and with a five year warranty.
upon first switching on I got the android loader on after a few seconds the tv just restarts itself. Tried a hard reset to no avail.
Any ideas? If not I'll call Sony tomorrow to try and resolve as I really want to keep the tv if possible.
thanks,
Matt
Hi there
See the following link:
https://us.en.kb.sony.com/app/answers/detail/a_id/75705/
However to be honest, if its brand new - just contact John Lewis again and get them to swap the TV with another one.
Thanks for the below @Anonymous.
ive tried the attached and still no luck, it resets but then the same thing happens. Could it be the power adapter?
Im going to give them a call today and see what they can do, as it was ex display I won't be able to swop it for the same model so going to see if they can repair it/track one down.
if not I'll end up buying a new model.
Thanks
Matt
Does anyone know what the Power Adapters should output in Watts? I have a feeling i might be using the wrong power adapter which might be casuing the issues im having.
I have 1 19.5V adapter which outputs 75W's which seems pretty low for a TV of this size.
Thanks
Matt
Hi there
I do not have the full tech specs of the mains adaptor, only that:
models with supplied mains adaptor only
19.5 V DC with mains adaptor
Rating: Input 220 V - 240 V AC, 50 Hz
Even though you have an ex-display TV, I would expect it to be working and with the correct mains adaptor/leads in the first place.
