Can any body help. amazon prime has worked on 2 occaissions on my sony bravia KD-55X8509C. Now it just tries to connect but nothing happens
Hi there
Have you managed to get this working now or are you still having troubles. Appologies for the delay in replying.
Amazon Instant Video stopped working on my KDL-42W654. I noticed that when I try to enable the service on the SEN website, Amazon Instant is not an option for this TV a 2014 model, but is for my 2 other Sony products, the 2013 version of the same TV and a Blu-Ray player, a couple of years older. Why would it not show up as an option? It works fine on both the older products.
Hi
Did you get this working ?
cheers
I have the same problem on a KDL-43W809C I selected:
Settings -> Apps -> Running Apps -> Amazon Instant Video -> Force-Stop
This sort of fixed it. I think...
Cheers, and good luck.
