I recently purchased a KD-43XE8077. Everything worked ok eccept the Amazon App. it would not connect cleanly. Either sound only, or frozen picture. It would only work properly once i had exited the app & restarted it. Following conversations with Sony in Cairo, their repair agents in uk & Currys Tec dept. i was advised to take the set beck for exchange. This i have done & the replacement set has the same problem! I have a full wifi signal on both 450GHz & 500GHz & have tried direct connection to the router via Ethernet cable but - the problem still exhists. All terrestial channels are ok, as are all other apps. The problem is only with Amazon.
Anyone else had the same problem? suggest a solution?
Every android tv shares the same Amazon app that is poorly implemented. Workaround is the bone you already pointed out: start a video stop it and restart: it would than play smoothly. The app should be updated with a better one in the next firmware.
Thanks Rooobb,
Let's just hope you are right! You are the first person to have come up with any form of explanation!
A dissapointing and frustrating start with my first Sony.
Tecdiver911
