Why can't I download the All4 app on my Android Bravia KD 43XF87 TV?
Hi @Lesc1556 Assuming that you are in the UK, you cannot download it from the Play Store because it is part of the base software. If you have YouView enabled then look in Sony Select.
Thanks. I'll try that.
