On my KD-55a1 there is no control app on the home screen for Alexa. I read on Sonys homepage that the TV was able to be controlled by Alexa but how?
Hi there,
Please check that you have the latest firmware on your TV. It introduces compatibility with Amazon Alexa compatible devices (UK only). You should then be able to run the 'TV Control Setup with Amazon Alexa' app.
Best wishes,
Ed
