I have just updated to 7.0 nougat on my KD55X8509C tv . I have a few problems
1 . No internet via wired ( only WiFi) worked fine wired before update
2. The Alexa app not present ( 7.0 nougat shows app in help menu to connect directly to tv )
3. No new PIP ( where you get overlay of secondary input)
Hi Mike,
I would suggest a Reboot and an update of the Firmware. You can find more details here. If this does not help then I would suggest a Reset of your TV.
Let me know if this helps.
Cheers,
Sean Mc
