Hello,
My TV Sony XR-55A80L
I cant connect via airplay. I get the pas code form TV, but it dosn’t work.
Both devices on the same Wi-Fi.
What the problem is?
Yes, it’s turned on.
Hi @Dbitute,
Make sure that the software is up to date for the TV, Airplay, and the mobile device. You can download the TV latest software v6.7630 from here: https://www.sony.co.uk/electronics/support/oled-tvs-android-a80l_a83l_a84l-series/xr-55a80l/software...
If the pairing worked in the past, that means it might be network-related. You can try the troubleshooting step starting from step 3 from this link: https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/xr-55a80l/articl...
