Yesterday I set up my new Bravia X90J and I'm generally very happy with it, so far. However, I can't get AirPlay to work properly when using my Mac.
What doesn't work:
1. When using Quicktime Player on the Mac and selecting to airplay to the Sony TV using QuickTime Player, the vide window says "This video is playing on "Sony TV" and the TV switches to the Airplay input window, as expected. However, the playbar isn't moving and no video (nor audio) is displayed.
What does work:
1. Airplay from my iPhone works without issues.
2. Airplay my entire desktop from the Mac also works (but with the usual lag that makes movie watching less than ideal).
Is this a known bug? Can someone reproduce it?
Quicktime on the Mac after selecting to Airplay. Playbar is not moving. Play/Pause does nothing.
Sorry, wrong forum. "X series" was a phone, apparently. Admin, please delete. I've crossposted to the "Android TV" category.
hi
did you solved this problem? I have the same issue
regards
Jarek
Hi @JarekP
You have replied to a old post from 2021. What is the full model number of your TV? It will start with KD or XR.
