Hi
I have bought this TV a month ago and I have problems to get sound from TV via ARC hdmi cable. First 15 days it works but I have restarted all the parameters and when I tried to configurate this tool sound from TV doesn´t work anymore. I have activate the HDMI CONTROL ON in A/V receiver but when I try to find the receiver with the TV Bravia sync tool, it doesn´t appear.
Has anyone this kind of problems?
Mikel
Hi Mikel,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi there,
I'd recommend making sure the TV is up to date:
If the issue remains, reset it to factory settings and try again:
Win_88
What make/mode of receiver?
I had numerous issues with mine, all now resolved (posts are up here somewhere :)).
