Hello Hannah,
For my KD-55AF9, the software version: PKG6.5076.0635EUA
When I go to ‘system update’ it says I am up to date.
hope this helps?
Hello Hannah,
KD-55AF9
software version: PKG6.5075.0635EUA
Hope this helps
Hi again. Did some digging after the solutions elsewhere didn’t work for me.
My problem has been solved (fingers crossed). For me the issue was from the Sky/Now router.
I split the 2.4 and 5 GHz bands by turning off synchronised tab, renamed them and disabled IPv6 on LAN side.
Hope this works for you.
Hey PaulinBont, do you use Sky ISP?
Hello Hannah, yes , I am with Sky for TV and Broadband
Regards
paul
Hey Paul, try fcookes's solution, obviously this is not an issue with the TV itself.
Thank You all for your help. I have contacted Sky and asked for their help.
I’ve spoken to the Sky technician and he thinks that it is a router issue-they are sending me a newer model. Hopefully this will resolve the issue.
Thank you all very much for your help
Hey PaulinBont, thank you, keep us updated.
Sky replaced my broadband with Superfast Fibre (100 mB), AF9 still showing ‘ tv not connected to the internet’ pop up banner.
Even when I enable WiFi in the settings, when I click ‘ok-connected ’ , ‘Internet Settings-Internet not connected’ shows up.
How do I get Sony to help resolve this ?
