Hi all ,
sony kd-55xf8096 android tv. can someone tell me how to download new apps , as when I go into settings-apps it says download but it is not highlighted so I cannot use it . Any ideas much appreciated.
thanks
Dave
Hi @mrmacca
You do not add Apps using the settings but use the Google Play Store on the Home screen. This is common to all Android devices like phones and tablets.
Hi @mrmacca
