Which TV? Thought the 2017 XE models already do support it? I am not sure whether earlier models will get it too. If you look at the spec sheets, you will find A2DP only for XE models. Might very well be a software limitation though, as SoC is basically the same for all Sony Android TV sets...
I dont think it ispart of specifikations of pre 2017 TV's so I doubt it will ever happen.
Can be a hardware limitation
