Hi, guys. My AC adaptor from my Sony Bravia TV stopped working after emitting some strange crackling noises.
I'm trying to buy a new one from the recommended site EET, but it seems that there are various compatible adaptors for my TV (85W, 100W, 120W).
My previous AC adaptor was a 19.5V, 100W, but the very same model is quite expensive on the site - close to 100€. 😞
On the site, they say that also the 85W model should be compatible with my TV (19.5V and 92W).
Do you think it would be compatible a 85W for a 92W TV or not ?
Thank you very much !
R.
@Rhadoo wrote:Hi, guys. My AC adaptor from my Sony Bravia TV stopped working after emitting some strange crackling noises.
R.
Hi @Rhadoo As this is potentially a safety issue I would contact Sony Support direct.
Thanks a lot for the answer and the link. I will contact Sony.
Have a nice day !
