Hi Winzy54,
Well, I don't think this is a feature that you can enable/disable as a user. Your best bet is to contact the app developer as they'll need to have a workaround for this feature.
All the best,
Tenneen9000
Hi.
The programmer already tried to workaround it. But with no luck.
Can anyone share a possible workaround that i could share with the developer.
Thanks for the help
