Partagez votre expérience!
Hey everyone. Yesterday my tv stopped working properly, from me it seems, that the internal storage is broken in some way or the soft is broke. I’ve tried to do reset as shown in the video (sorry for the length)
also did hard factory reset (which is not working - it does not do anything only power up the tv again with the android logo)
In the video I tried to do soft factory reset but again you can see, it only restarts and here we go again.
Tv no more shows the Sony logo instead it always start up with android logo.
In the setting everything I change erase in the next restart and is at it was in the startup.
The tv also start/restart/shutdown by itself.
It all started when I turn on ps5 then switch to sources HDMI it goes normally and after 10 s (I was launching a game) it started to do this problems…
I am really desperate cause i tried everything….
Here is a link, cause I cant upload it here:
hello @MikeyCZ
your device might need to be looked at by a repair technician,. try to book a repair .
