When I listen to Spotify on my TV via my A7000, the screen saver is activated after a while and ruins my music experience and it's annoying. So I have to turn off the screen saver before listening to Spotify on my TV. Anyone else experiencing the same thing?
As yours is an OLED TV you should make use of the Picture Off feature from the Settings button on the remote control. This means you can listen to radio, Spotify or similar without the panel being on and risking screen burn.
As yours is an OLED TV you should make use of the Picture Off feature from the Settings button on the remote control. This means you can listen to radio, Spotify or similar without the panel being on and risking scene burn.
Thanks
