On the TV I have added a 1tb drive, and formatted it to sonys format for extra apps, now Sony formatted it to 322gb approx. that ok. As you see below using FX apps I only have 2.3gb left internal memory, what I want to do it to be able to add mp4 etc to the hard drive, but the only thing I can put on the extra storage is apps, the mp4 etc use up the 2.4gb left
What I want to do is to create a folder where I can store files on the hard drive. I know I could format the hard drive as external drive but I could not use this for apps that’s why I formatted it to be used for apps
Hi petepots, you can call Sony reps to double check as well! Good luck. ^^
Hey petepots, I don't see another solution but to use a different hard drive for the MP4s.
Agree Hannah
I have tried averthing, never mind
Take care and thanks for your time in replying
Thanks Hannah
I will ask them
