My TV is the 43XD8099 (which i am told is ATV2) and able to update better than ATV1
With the 6.2602 Nougat firmware, I thought my TV would get all the improvements - it gets NEARLY all but for some reason not the A2DP bluetooth profile.
Does anyone from the forum, or from Sony know if this is because they haven't got round to it or is it something to do with the chipsets used in the 43XD8099.
I had understood that because this model could handle things like Picture in Picture and the other new upgrades that A2DP would be included.
Any thoughts anyone ?
You should try to contact the developer of the third party application , the tv by itself does not support a2dp Bluetooth devices
ok, but the problem appeared after updating the TV to Android 10. Why didn't they leave this option enabled if the TV hardware supports this option, even with a third-party application. It seems stupid to me to have a SONY TV and not be able to connect headphones or a portable speaker to it... and they are all.... SONY
P.S. Wi C200, wh 1000xm3, wh 1000xm5
Hi @gica2000, third-party applications might help. However, their effectiveness can vary, and they might not be officially supported by Sony.
