IR Blaster setup to control a Sky+HD box, and most controls work fine however, the UP/DOWN/LEFT/RIGHT navigation buttons work, but always send 3 occurrences of UP, DOWN, LEFT, or RIGHT instead of just one occurrence.
So, for example, when navigating the Sky+HD box list of recordings, pressing down skips down 3 recordings, making it impossible to select the recordings in-between, same thing when selecting channels, using the navigation bar etc.
Anyone else with the A1 got the same issue? Any solutions that will make the UP/DOWN/LEFT/RIGHT buttons behave correctly?
Sony fixed this last year, seems they have broken it again. Need to wait for firmware update from Sony.
